Hi Florian,
Thanks for putting this question on a new thread!
The trick is to create input aliases for each and then define 2 separate presets with each preset looking for input on it’s device (overriding the project defaults).
For notes, you will likely have to convert note-off with velocity of 7F (APC-MINI default) to note-off with velocity 0
Since faders are on the same MIDI channels of notes, if you want to use them you will need to put them on MIDI CH 2 for your first APC-MINI.
For your second one, you should convert all note output to MIDI Channel 3 and fader to note on MIDI Channel 4.
Then send all your output to GMA2 as normal on a single MIDI port.
The attached should work.
You should assign The Alias APC MINI-1 to your first APC MINI and APC MINI-2 to your second one.
Assign the alias GrandMA to whatever port your are using in GMA2
The first preset has 3 translators.
The first one handles note-on with no changes.
The second one converts note off to output value of 0 instead of 127
The third one converts the incoming CC (fader) to a note and sends it out to MIDI CH 2 with the incoming velocity of the fader.
The first preset only monitors input from the Alias APC MINI-1
The second preset only monitors input from Alias APC MINI-2 and does the same thing with the following exceptions:
It translates all note-on and off message to go out on MIDI Channel 3
In addition to converting from CC to note, the outgoing notes are directed to MIDI channel 4.
I hope this helps!
1571956400562_2-APC-MIN-to-GMA2.bmtp
