What I'm trying to do is this:
I've used a rule to change pitchbend to control expression, and I've currently set it so that it's default is value 80.
The idea is that when I use the pitch bend, there are times when I want the value to remain at its instantaneous value, so releasing the pitchbend wheel doesn't return the expresson back to 80.
Currently I've programmed it so that when in the default position, the pitchbend wheel (through a rule) sets the expression (cc11 to value 80), with a range of 0 to 127.
What I want to do is to tell BOME to ignore any pitchbend data if I press a button on my keyboard ( that sends CC16, value 127). If CC16 has a value 0, then the pitchbend data should be processed
Is this sort of thing possible?
