Hi All,
I want to connect two X-Touch Mini to BMT. The midi port name is burned into the firmware and cannot be changed. Will the two ports conflict in BMT or can I use an alias to talk to each controller individually?
Wanted to ask before I buy them.
You can use two of the same controller. They will each be given a unique name by BomeBox.
If you want the same controller to always be the primary controller, then just always plug them in the same order into your USB hub.
Steve Caldwell Bome Customer Care Also available for paid consulting services: bome@sniz.biz
