Variable Storage in File on BomeBox
From testing I can see that using file storage works on the BomeBox as well as on a computer. I have two questions:
  1. How can I access and download the modified file on the BomeBox?
  2. Can I upload a text file that already has variables in it?
Thank you for any help!
I just thought of testing a project loaded from a USB drive, and the text storage file was saved back to the USB drive, where I can easily access it or upload a new one. I"m still interested in whether a text file can be retrieved from the BomeBox directly.
Hi Doug,
at this time, there is no ‘normal’ way to directly access storage files saved on the BomeBox itself (except when running the project from a USB drive). I would recommend logic in the project file to initialize the storage file if it is not there.
A wacky way is to access the storage file via Backup. You can create a .bbox backup file and extract the var storage from it, and even modify it for a new .bbox file to restore from.
Please be very careful. Have a thumb drive ready for Reset to Factory Defaults.
  • in the web config, go to Settings/Backup
  • save Backup file
  • .bbox files are just .tar.gz files, so you can open them using tar xzf file.bbox or using a zip app like 7zip
  • you can extract and change the storage file under the /projects folder
  • compress back to .tar.gz and rename to .bbox
  • in the web config, load this file as Restore.
Great info–thank you!
