Hi, we are happy to announce a two part tutorial to show you how to use a MIDI Controller to work as an IR remote controller. So you can control pretty much any device which has an infrared remote -- using MIDI!
Part 1: How to build the solution with Bome MIDI Translator Pro: https://youtu.be/BQ_MXdkXpiE
Part 2: Put the solution on the BomeBox: https://youtu.be/78atPb_gDdg
The MIDI Translator project file from the tutorial is attached below.
Hex Loader for Mac: http://www.polaxis.be/download/easyuploader-for-mac/ - Use ATMega328p as device type Hex Loader for PC: http://xloader.russemotto.com/ - Use ATMega328 as device type
Bome Hex Code Download (.hex file):
https://github.com/bome/irdroino/tree/master/Software/irdroino_remote - File name irdroino_remote.ino.standard.hex
Irdroino alternative 1:
https://irdroid.eu/product/pronto-usb-ir-blaster-kit/
optional enclosure, something like this will work:
https://www.amazon.com/dp/B075SX6WYJ/ref=cm_sw_em_r_mt_dp_U_PGk1CbCZCNRCF
Irdroino alternative 2 (with half-height enclosure): https://irdroid.eu/product/irdroino-pronto-usb-ir-blaster-kit-enclosure/
Steps (see tutorials for full explanation):
- Download Hex Code
- Download Hex Loader Program (based on current OS platform)
- Use Hex Loader to load Hex Code into Arduino
- Open / Create Bome MT Project File
- Learn MIDI Codes using MT Pro
For running on BomeBox:
- Connect USB hub to BomeBox
- Connect MIDI Controller to USB hub
- Connect Irdroino to USB hub
- Upload Project File to BomeBox and select it
- Check web config pages: MIDI Ports and Serial Ports
1557442863832_IR-Remote-Bome-Tutorial.bmtp
