Hi Guys.
I'm building a dual-tier keyboard setup with pedal board. Each of my three levels requires a few USB-A midi ports and a few DIN ports; all ultimately connected to my Bome Box. I'm trying to keep pre-show cabling to a minimum.
Given my setup, is it possible to create a single-wire connection from tier to tier? (I mean without purchasing more Bome Boxes. ;-) ). For example, can I put a USB hub on each tier and feed them from a master hub without fouling the BomeBox's USB-MIDI porting? (Obviously there is a power restriction... but otherwise?)
I could build this device and add some shielded and buffered I2C jumper cables to solve the DIN problem... but I would still need to address the USB separately. It seems cleaner to build USB distribution (with its phantom power) and convert to DIN wherever necessary.
Suggestions?
