Hi-
When I set my WiFi to default (HotSpot) the WiFi light behaves as expected, it blinks when first turned on then goes solid. When I set WiFi to “Access Point” the WiFi blinks when turned on and stays blinking, but WiFi seems to be working OK, just keeps blinking : (
This persists with re-boots etc. Perhaps this is because of fixed IP somehow on Ethernet side?
Unlike a hotspot which provides it’s own network address (192.168.153.1 by default), an access point must obtain a network address through the ethernet side of the BomeBox interface. If the ethernet side of the interface is a DHCP master, then BomeBox will provided the address to the WiFi Interface. If the ethernet side is set as a client (the default), the master on the ethernet side will assign the network address.
In you situation, you probably have the ethernet side defined as a client and as such, there is no IP address being assigned to your WiFi unless you hook up your ethernet side to an existing network that has a DHCP master.
Hi, I don’t believe that the WiFi is assigned an IP address if you have the ethernet set up as a fixed IP address. It would need to be a DHCP master (with no other masters on the network) or a DCHP client (where the master on the ethernet side assigns the address). You would instead, need to set up Wireless as a hotspot and not an access point.
Is there something you are trying to accomplish or are you just exploring?
Then you should probably set up the ethernet side as either DHCP master or DHCP client depending on your network configuration. Is there a reason you set up your ethernet as fixed IP?
Yes, well the issue will be that if you don’t have something acting as a DHCP server, you might be able to connect wirelessly to your BomeBox if your ethernet has fixed IP, however since there is no DHCP server, the client you use for connecting would also have to be fixed IP on the same network as your BomeBox.
I believe in the fixed IP configuration on ethern,t , your WiFi has the same IP address as your ethernet, yet again, no way to dish out IP address to other WiFi Clients when they connect.
Hi, chiming in… this seems to be a bug in the firmware. It should not blink, but the firmware waits for a notification so that it stops blinking. It seems that this notification is not generated when it is using a static IP address. Sorry for that! Will be fixed in the next firmware version.
