Good Morning,
I currently have BMT Pro and Ableton Live (12) running on my desktop with 4 devices connected via USB on the host: An MPK249 (Routed to BMT 3), a Squarp Hapax (Routed to BMT6), a Midi Fighter Twister (Routed to BMT 2) and a Streamdeck (BMT 5).
I also have ClyphXpro (script running in Live with BMT1: In and Out) and a Push2 (Not routed via BMT pro but with plugging/unplugging detected in my script).
Please see the attached BMT project file : LPA32.bmtp (206.0 KB).
Please note that BMT 1, BMT2 and BMT3 are assigned to Control Surfaces in Live, which mean the communication is by directional.
I would like to use a Bomebox to connect these devices to the host via Ethernet, mainly for facilitating the switch to another computer (Laptop) without re configuring everything. I would use (export) my BMT Pro setup on the BomeBox.
Now I am worried with one of your statement :
BomeBox current firmware does not detect Direct MIDI ports on the computer, so anything coming from the computer will be seen only on the main network port.
So my questions :
- How can I overcome the host ‘single port’ limitation ? I thought about specializing each of the control surfaces script to some channels so I am able to process them appropriately, but that would require a lot of changes and I am not sure it would resolve any potential conflict.
Is there any other solution ? - More generally speaking, will my setup (quite a big project) run on a BomeBox without difficulties?
Thanks for your support.
Have a good day.
