Hi, I’m running Pro Tools 12, trying to use cheap controller (Worlde Easy Control 9) and had no success.
I tried to get some exemples, but couldnt get the faders working on Pro Tools, is there any help?
(Configured - Pro tools/Setup/MIDI/MIDI Input Enable/BMT 1 + Worlde Easy Ctrl)
(Configured - Pro tools/Setup/Peripherals/MIDI Controllers - HUI - BMT1 - BMT1 - 8)
Well since this controller is programmable, the attached project may not work for you. You may need to change the incoming triggers based on the CC messages your fader send.
With Mackie HUI (which is what ProTools uses), you will only get the use of 8 faders ad the HUI device does not have a master fader.
Also the EasyControl 9 does not recognize LED feedback so you will not see anything on the buttons.
The example below is just for faders as an example. Reach out to me for paid consulting if you want a complete implementation.
You should still be able to use the transport buttons and the bottom buttons (with no LED feedback).
Worlde EasyControl 9 Fader example.bmtp (3.5 KB)
If it doesn’t work. I may need to add a translator with a HUI ping reply. Some DAWs require that but I’m not sure if ProTools is one of them.
