Yes, you can do this with Bome MIDI Translator Pro. You will need to know that Mackie MCU or HUI commands to use for conversion but it is quite acheivable if you know them.  You can also set up for 2-way communications so that if your software sends out CC (say to move a fader), it can translate back to the appropriate Mackie MCU or HUI command for the controller.
I can provide a few examples here on this forum as free support if you would like. However for a fully built solution, this would require paid services which I can offer if you would like. If interested in a full solution, let me know via email. If you want just an example, then maybe what I should do is an example of 1 fader conversion.  I recommend Mackie MCU mode over HUI as Mackie MCU supports a master fader in addition to the 8 channel faders.
In general you would set up Mackie MCU fader 1 with incoming trigger of raw MIDI E0 pp qq and outgoing message of B0 xx pp (where xx is the CC number you want to use and pp is a local variable which is just passed through from input to output). The variable qq is discarded on output
For the reverse (lighting software to X-touch) you would need incoming message of B0 xx pp (were xx is your controller number) and output of E0 pp pp. Back to the console.
Make sure your translators (or presets) are set up so that you pick the right input and output ports only for these messages (so that they don't go out unintentionaly to other MIDI ports that you do not want to send to.
I would recommend setting up aliases "From Mackie Application" and "To Mackie Application" and assign the Bome MIDI Translator Virtual Port 1.
In your app, it will probably show as "BMT 1" instead of the full name but you can change that in the settings menu of MT Pro.
So the flow goes:
X-touch -> Bome MIDI Translator  Pro-> BMT 1 output
BMT 1 Input -> Bome MIDI Translator Pro -> X-touch
You can download the trial copy to make sure it is working as desired prior to purchase. It is fully functional but just times out after each 20 minutes of use where you have to re-start MT Pro if you want to continue testing.
Download link:
https://www.bome.com/products/miditranslator
