Hey - may this Voile work for Yamaha01V96?
I have the preset for Yamaha DM2000 but there only work Ch.1-8 ![]()
If you set up Cubase for 2 HUI Devices, the first one would be on BMT 1 and the second on BMT 2 with the fader messages going to BMT 2 with the same as BMT 1. Cubase will recognize that as a second HUI device. So the incoming messages from your controller will need to be different for Track 9-16 while the outgoing messages the same but on BMT 2 (second HUI device).
If you have the project file that you are trying, I could take a quick look at it to see how much work it is to fix it for the next 8 tracks.
Of course, I would need to know what MIDI messages your second set of faders send.
I’m not 100% sure what SysEX messages your faders send but this should be pretty close. Since I don’t have an O2R, I used an emulator to create the SysEX messages but I disabled the emulator preset.
Make sure you set up your aliases correctly for the input of your O2R and the output of Cubase.
Here is how I set up Cubase:
O2R-MCU-Fader.bmtp (1.6 KB)
Hey Steve, thanks a lot.
I think I will try it with Ableton instedt of Cubase.
It is the Yamaha 01V96 which I use.
OK, in that case, I moved this to a new topic.
