Well one thing that confuses me is that you have a few duplicate values in your input message. Last 3 lines on 0 to -18. With that said, this should get you pretty close
Input
Raw Midi
F0 43 10 3D 00 06 20 pp qq F7
Rules
//pp = msb
//pp=2
//qq = lsb
//qq=4
// value byte rr
rr=pp<<4
rr=rr|qq
if rr>127 then ss=rr-220
if rr<=127 then ss=rr+34
/// Now lets convert the range
ss=ss*1000
ss=ss*128
ss=ss/70
ss=ss/1000
if ss>127 then ss=127
I have the V2 version. Since i allready been pritty far for remote. Steve has been helping mee really nice, with writing the correct code’s.
Only the eq section has to be done.
But still a problem getting pan center in cubase.
Absolutely…its up already in the old forum, but I’ll save a version that doesn’t have any experimental stuff I’ve added for my d8b.
Does cubase support hui? I use reaper and have used logic.
I hope I’m not butting in ..Steve..and sbtevoortwis.
If I’m not mistaken, there is a pro tools setting in the o2r? That would be hui.
If cubase does support hui, then that would be easier than anything.
If my present can be educational in the process..meaning the documentation of what MCU buttons put out and visa versa w hui then have at it:-)
Cubase does support mackie hui and mcu so I think it has to work.
I can not use the pro tools remote setup in the O2r mixer and general midi remote setup can only control faders.
The below project is what I used for testing. First since I don’t have an O2R, I tried to simulate it’s output with my local controller (Launch control) and set a translater from my CC to expected 02R output. I sent that to midi yoke 1
Then I took the input from midi yoke 1 (simuleted Sysex) and ran it to my logic that I provided you and sent output to midi yoke 2 for testing.
So the flow is my cc to Sysex translation -> Midi yoke 1 Sysex -> Sysex to cc translation -> Midi Yoke 2
Attached is the file with the two translators enabled
I tried the gain function it’s pritty close well done!! The center is a little of.
But I imagine that’s maybe difficult to get right. Or do you have a suggestion?
Maybe because the O2r has 18dB -/+ and cubase 24dB -/+ ?
You might want to tweak the numbers or scaling a bit just like you did with pan, but I suspect you will run in to similar issues. Unfortunately this is not an exact science when you translate from one technology to another that have varying scales and precision.
I think the middle would be value 64 and now it 1 step to left 64. And the middle is now 62 and 1 step right is 64.
I can tweak this because there are 2 values 64 and two values 62. Can I do something about this?
Otherwise I leave it like this.
This is the one i uploaded awhile ago……I need to modify what I’m using now an resave it..could take a bit.
From what I remember of my buddys o2r, you should be able to use hui for the basics, then mtp for any other thing. That the Tammy will spit/receive ,that is.
TellSteve he does awesome imho. The math would cripple me:-)
