Hi Steve. Here’s a follow up question for the MIDI note to MIDI CC
Say I have these Constant CCW-CW Midi note trigger assigned in a VIAL QMK board.
note that Vial QMK doesn’t send MIDI CC only MIDI Notes.
SO I assigned the rotary encoder to send two different Midi Notes for CCW and CW.
CCW = Note On A#7 Velocity 127
Note Off A#7 Velocity 127
CW = Note On B7 Velocity 127
Note Off B7 Velocity 127
I wanted to have a layer assignment for another Function
If Note On C5 Chan16 is Pressed (Layer 1)
It will send the Constant CCW-CW to
CCW= CC70 , Velocity 63
CW=CC70, Velocity 65
If Note On C#5 Chan 16 is pressed (Layer 2)
CCW= CC71 , Velocity 63
CW=CC71, Velocity 65
If Note On D5 Chan 16 is pressed (Layer 3)
CCW= CC72 , Velocity 63
CW=CC72, Velocity 65
If Note On D#5 Chan 16 is pressed (Layer 4)
CCW= CC73 , Velocity 63
CW=CC73, Velocity 65
If Note On E5 Chan 16 is pressed (Layer 5)
CCW= CC74 , Velocity 63
CW=CC74, Velocity 65
If Note On F5 Chan 16 is pressed (Layer 6)
CCW= CC75 , Velocity 63
CW=CC75, Velocity 65
If Note On F#5 Chan 16 is pressed (Layer 7)
CCW= CC76 , Velocity 63
CW=CC76, Velocity 65
If Note On G5 Chan 16 is pressed (Layer 8)
CCW= CC77 , Velocity 63
CW=CC77, Velocity 65
If Note On G#5 Chan 16 is pressed (Layer 9)
CCW= CC78 , Velocity 63
CW=CC78, Velocity 65
If Note On A5 Chan 16 is pressed (Layer 10)
CCW= CC79 , Velocity 63
CW=CC79, Velocity 65
If Note On A#5 Chan 16 is pressed (Layer 11)
CCW= CC80 , Velocity 63
CW=CC80, Velocity 65
If Note On B5 Chan 16 is pressed (Layer 12)
CCW= CC81 , Velocity 63
CW=CC81, Velocity 65
Help Please. Thank you so much.
