I have been using Bome for a good few months now and its been working great!
I do have a little issue with buttons lighting up incorrectly or just showing white when they have nothing assisnged.
May jusy be how I have set it up?
I run a Akai mini MK2 as channel 1 going straight through and the Launchpad coverted to Channel 2.
They are then sent via RTP midi to Daslight 5
I have added my file
If anyone has any thoughts please shout up Quorn Midi Control.bmtp (1.4 KB)
Unlike the APC-MINI MK1, the MK2 has a different color map.
In general, for brightest LEDs, you should sent MIDI Note-On on MIDI Channel 7 instead of MIDI CH1. This is true for the matric buttons only. For the bottom and side button, continue to send on MIDI CH 1.
This posting documents the different velocities for colors and more details on the APC-MINI MK2 protocol.
White would be a velocity of 3 for the APC MINI MK1 I believe this velocity is for red (but MIDI CH 1).
Right, Ive got the mini running on 1 and 7 at last but i am now struggling to do a simple channel change on the launchpad. I would like it on 10 but im failing! Quorn Mini and Launchpad CH change.bmtp (5.0 KB)
Your translator 2.0 handled MIDI CH 1 to MIDI CH 10 correctly.
Just read the LP manual. In some modes, I don’t think you can define the colors remotely. There should be a color map with velocity values in the Launchpad manual
