APC Mini Button Lights
Hello. I have a question about Bome and the midi controller APC Mini.
  1. I would like to light up the APC Mini via Bome. So I want to give each button a color. How can I do this through Bome?
  2. When I open Bome, the lighting should be loaded automatically. Does it work?
    Maybe someone can explain it to me exactly or via teamviewer?
I hope you can help me
Thanks. All the best
By default the APC-MINI lights do not light up. You need to send MIDI data to them to light them.
The attached post should help. It mentions Dot2 however neither GrandMA nor Dot2 send MIDI feedback by default so you would either need to script it (in Lua) or use MIDI Translator to provide LED feedback as shown by the example in the below post.
