APC40 MK1 dot2
Hallo Zusammen,
ich benötige ein BOME Template für ein AKAI APC40 MK1 zur Benutzung mit dot2.
Kann jemand helfen?
Danke und viele Grüße
Markus
You can check out this post and it might give you want you need. The key things you need to do are:
  1. Map faders and knobs (CC Message) to note messages as dot2 will not accept CC message. Make sure the message you map to are not the same as any of the note messages your buttons send.
  2. I’m not sure if you can get LED feedback from dot2. I know that some have wrote lua script to provide feedback from GrandMA2 back to the controller. If this cannot be done, then you would need to program LED feedback in Bome MIDI translator and it may not always be in sync with what dot2 status.
This template may also help you at least get started.
APC40_dot2.bmtp (9.1 KB)
