A double click will require a repeating timer with a count of 2 with the outgoing action for each iteration being a mouse click.
So for one translator you have incoming MIDI with outgoing being timer “double click” with 2 iterations.
For the second translator the incoming is timer “double click” with outgoing action of click up and down.
For more complex sequences, you might have to use a global variable with the same incoming action and then increment the variable each time so that only one of the translators fire at a given time.
For instance say you have incoming CC#0 on MIDI channel 1 any value set to ga.
The outgoing action is click down and hold
Initially gb=0 so you only execute the above action if gb is 0 and in rules you increment gb
if gb>0 then exit rules, skip outgoing action
gb=gb+1
Then the next action would be drag with the same incoming trigger
if gb!=1 then exit rules skip outgoing action
gb=gb+1
// set pp based on value of ga (rules excluded here)
pp=ga
Outgoing move mouse right value pp
You also add a watchdog timer to release the mouse click down (do a click up) if the knob has not moved in 1 second
Incoming Trigger :same
Outgoing action : Timer “click up” delay 1000 msec
Finally the click up timer (when the knob stops moving)
Incoming Timer “click up”
Outgoing: mouse click up
As long as the knob is turning, the “click up” timer will never trigger because it gets reset by moving the knob. When it stops moving for more than 1000 msec (1 second), the event triggers therby releasing the mouse. The rules of this timer should also set gb back to 0 so the sequence can start all over.
I posted some examples here in the last week or two,. Search for mouse, or Davinci, or Resolve as I believe this is what the user was specifically asking.
