So I am having a lot of trouble getting BomeBox to recognize all of my devices at the same time. I purchased BomeBox as a solution to not being able to find a USB Midi Host that would work with a large number of USB devices. I have about 20 controllers and instruments I’d like to utilize through USB, but I have not been able to get BomeBox to recognize them all at once.
The devices are spread between two USB hubs, one into the second and the second into BomeBox. If I start the device with all of them plugged in, it will only recognize a handful of them. If I activate them one at a time by disconnecting the cords and attaching them one at a time, I can get up to about 12 devices before BomeBox refuses to acknowledge any new ones. All devices are class compliant and I have been able to get each device recognized individually…I’ve been at it all day and have at one point or another seen every midi device on the menu, but not all at the same time. I am running the latest firmware and have attempted several factory resets to no avail. Please help!
I’m sorry you are having issues! I don’t think there are any hard limits. Let me check further and get back to you. I assume you are using powered USB hubs as 20 devices without powered hubs could certainly draw too much current.
Also, how are you powering your BomeBox and if you have a list of USB devices that might also shed some light on the situation.
Yes, I am using powered hubs. The BomeBox is being powered through USB. If you think Ethernet power would solve the problem, then I will order one. Is that a Cat5 or Cat6 cable? Do you think that’s the most likely problem? I’ll get a list together of the devices, but as I said I have been able to get the BomeBox to recognize each device individually at some point so it seems like it’s the BomeBox and not the devices themselves.
Also, if it isn’t too obvious (haha), I have absolutely zero knowledge regarding Ethernet power. Looking at 48v injectors on Amazon right now… is 15w enough? Or is 30w more suitable for the issue I’m having?
I find my POE much more reliable than USB because it has higher voltage and a connector that is less susceptible to come loose. But I don’t think this is the issue. My guess is there may be a firmware update required due to the default settings of the current BomeBox firmware. Not many people use this many USB devices and although it is not a hardware limit, there may be a parameter in kernel software (which would require a firmware update) that is causing the issue. I have escalated the ticket in case this is the issue. But best to look at all other possible causes in case I’m wrong.
This is the POE that I have (24w) and it seems to do the trick. The cable is CAT5.
Again, you may not need it and there is seldom an issue with wattage when you have powered USB hubs. For me it is a matter more of using an unpowered USB hub (1wMax) or having a connector that won’t come loose.
OK, I have a feeling that the power may not be the issue as well, especially if your expertise is pointing you towards a firmware issue. So, I take it, this is going to be a wait and see thing on my part?
15W should be plenty. You will still need powered USB hubs as this power supply will not increase the wattage requirement coming from BomeBox through the USB host jack.
Sounds good, I’m also reading up on how nesting hubs work. For instance a 7 port hub is really 2 4 port hubs nested. I’m not sure how the architecture of a 10 port hub is or you might even have 2 16 port hubs. Maybe if you plugged each of your 2 powered hub into a 4 port non powered hub instead of nesting the then together, there would be less nesting layers and it would work. Again, I’m a little rusty on how large hubs are nested
For the record, it’s a 16 port hub and a 10 port hub. Also, in terms of the firmware, it might be worth noting that a few of the devices present more than 1 port when connected… some of them present 2 and one of them even presents 5, so that might need to be taken into account in terms of the quoted amount of 20 devices.
OK, I think a 16 port hub is 5 4 port hubs cascaded (4x4port hubs cascaded to another 4 port hub)
A 10 port hub is usually 3 4 port hubs cascaded - (2 cascaded from 1)
So cascading 1 off of the other might make it too deep
Also, if I were to suspect any devices that expose more than one port, my suspect would be on the one that exposes 5 as typically class compliant devices do not have odd numbers of exposed ports.
I think there is a limit of 8 exposed virtual ports on any given physical USB device but I think that is the kernel config I was talking about about. I think the plan is to expand that in a future firmware revision. I’m not sure there is any limit (beyond the USB 255) device addresses otherwise. I’m not sure if there is a limit on the nesting levels.
If you have an unpowered 4 port hub, try plugging that into BomeBox and then each of your two powered hubs off of that. It will probably reduce the nesting levels depending on how your hubs are built.
Just tried with the unpowered hub. Still coming up short. I think it was 14 in, 16 out this time. A little higher than before but still not all of them.
The device with the numerous ports is the Novation SL MKIII. I believe it’s 3 inputs and 5 outputs. Otherwise, my Launch Control XL and Launchpad Mini MKIII, as well as my Minilogue xD modules, all expose 2 ports each.
So do you have 20 physical devices with more than 1 logical port each or are you talking about 20 logical USB device ports. I think right now there is a limit in the software of 8 logical devices per 1 physical USB port but I think that will be increased to 32 logical devices per physical port. My memory is not to good on this though so I might be wrong. I think the more information we have on your configuration, the quicker we will be able to solve this. In general I think USB allows 7 nesting levels but some computers choke when going more than 3 levels. I’m not sure of the BomeBox spec but I think the levels is tied more to software than hardware.
Aha, the plot thickens. Florian is in Germany so he will probably answer before I get up tomorrow morning. He is the owner and developer so he would probably need to provide the fix. I’m in Portland Oregon. I’m feeling more confident that it is probably the kernel config and that a custom firmware update will be required until new standard firmware is available. Hopefully he has a build for you already and that if not it won’t take long (no promises though from me). He is usually good about this type of thing.
