Wolfmix and APC mini mk2 - LED Feedback
Hi, sorry for my expression, I’m new here. I bought MTP and the Bome Box to map the DMX controller Wolfmix W1 mk2 with Akai APC mini mk2. That works well, but I wanted to transfer the LED behavior from the DMX controller sycron to the APC. In short, when I press a button on the APC or W1 active, the other active button should stop (flashing). If possible, the active button should flash.
The colors should look like in the project.
I also have a template of the LED matrix. How do I go about implementing this?
Project Wolfmix.bmtp (2.0 KB)
They key question here is whether Wolfmix sends any MIDI when accessing it directly. We would need to see what messages it sends out and determine how to process these messages in BomeBox to reflect the LED behavior on your APC-MINI MKII.
If you open the log window in Bome MIDI Translator Pro and click the MIDI In check box, you should be able to access function on Wolfmix and see what it sends.
Hello Steve. Thanks for the quick response.
I pressed 5 buttons and received the following response from Wolfmix, see the picture
What picture?
Sorry, here it is .
So it looks like by default, the MIDI message going back is the same that your APC MINI MK2 sends. Is only one button on your APC-MINI supposed to flash at a given time and the others as used as startup colors?
Yes exactly, I just want to know which key is active, the others can light up permanently to know where I have saved something
OK, so I mad a few changes.
I renamed your first preset ‘Init’ and created a method where either opening the project or sending a keystroke Control(Right) will trigger the initial LED refresh.
I added a second preset that only listens to Wolfmix for incoming triggers and send output only to your APC MINI
I put the timer translator in that preset since you only want to be sending notes to your APC-40 for LED refresh
I added a note-on translator that will take the incoming note and update either global variable g0 (for first 32 notes) or global variable g1( for last 32 notes). The global variables will control a bitmap of which note was pushed after clearing all notes.
In your timer, I look at the bitmap to determine which note I want to modify for MIDI CH 8 for flashing the LED. All other channels will send the default channel of 7. I set the local variable vv for the desired outgoing channel.
Here are the rules that I added.
// Look for bit set
// determine global variable to use
if tt>31 then rr=g1
else rr=g0
// Mod operator
ss=tt%32
// put pit into first position
uu=rr>>ss
// mask all other bits
uu=uu&1
// set desired outgoing MIDI channel
if uu==1 then vv=7
else vv=6
Here is the project file.
Project Wolfmix-sjc.bmtp (3.6 KB)
Wow, Steve, that’s exactly what I wanted. And it works great.
One more thing, where do I set the blink rate on channel 15-14 for a gentle frequency?
Thanks in advance for your help
Hi Steve. I figured it out. Thanks again for your help. I wouldn’t have been able to do it without you. :grinning:
[image]
Hello Steve.
I would like to ask you for advice again.
I have reduced the blinking frequency but it doesn’t go off completely (0>127, 127<0) so it’s hard to notice it.
How/where can I do that?
The blinking frequency is controlled by the MIDI controller internally based on the incoming MIDI channel. The note number only represents the color.
Any other blinking method we would have to have another periodic timer control it within Bome using solid colors with the controller.
See this posting,
Too bad.
Would it be possible to assign a different color to this flashing LED? ( Red )
I have to recognize the active button otherwise I’ll get confused with the operation
Add this as the last rule on translator 1.2
// Color
if uu==1 then qq=72
Hi, thanks for the tip. I added the sentence and now I have a clean blinking frequency. Just as I wanted -
Perfect.
Thank you.
// Color
if uu==1 then qq=72
if qq==72 then vv=15
Here is if you want more precise control of the Flashing LED. The flashing is done with a separate timer in MT Pro. You can define the on color, the off, color, the intensity, and blink rate. This is all done in the following rules of translator 1.2
// Color
if uu==1 then Perform "Blink",1,vv,tt,72,3,500
// first param 1=start 0=stop
// second paramter= brightness MIDI CH
// third paramter= note number
// forth paramter=on color
// fifth parameter-off color
// sixth paramter is rate in ms
I now have the following rules for setting global parameters in the rules of translator 0.2
// set up bitmap
// first 32 notes in g0
g0=0
// second 32 notes in g1
g1=0
// Iteration counter
ga=64
// blink on color
gb=72
// blink off color
gc=3
// led intensity MIDI CH
gd=3
// blink state 1=on 2=off
ge=0
// blink note number
gf=0
Project Wolfmix-sjc-2024-12-21.bmtp (5.7 KB)
Hello Steve.
Thanks for your great support. I tested your file and modified it a little to suit my needs. Now it works even better than before.
I will import it into the BomeBox soon.
Wishing you a Merry Christmas from Germany.
Merry Christmas from the USA!
Hi, Roland and Steve
I am not able to get my Bome to recognize the Wolfmix controller so I can map it. Is there a special step to get it to connect?
Max
It appears the the the Wolfmix is a USB host. I assume you are trying to connect it to BomeBox or another USB host. USB host to host connections are not possible.
To connect to BomeBox you will need a USB MIDI to DIN adapter simlilar to this. Don’t by a cheap adapter as if you do, some MIDI messages may not pass through since cheap adapters have small buffer size. Then connect the MIDI DIN Connector to the BomeBox DIN ports (in to out and out to in).
For connecting to a computer, you will need another USB to MIDI DIN adapter. In this configuration wach USB connector would be plugged in the the host (Wolfmix and Computer), and then the MIDI DIN connectors would be plugged together (in to out and out to in).
