Cross-Reference List of all Variables in a MT Pro Project
A user of MIDI Translator Pro created a small utility to create a cross reference of all used variables in a MIDI Translator Pro project. It outputs two lists: 1) by variable in which translators the variable is used, and 2) by translator, which variables are used in a given translator.
Such functionality is planned for a future version of MIDI Translator Pro, but for now this utility might be useful for you.
Usage: 1) open the project file in MIDI Translator Pro 2) Use File|Export Project As Text to save the file as a text file 3) run the attached .exe file (a command line window appears) 4) from an explorer window, drag the exported .txt file to the command line. Press the BACKSPACE key 4 times to remove the .txt file extension, then ENTER 5) the program creates a file with appended name "-Liste Variables.txt" which contains the cross-reference
Note: the program is French, but it should be easy to use it with the instructions above.
Example output:
C:\Novation_Launchpad_Pong.txt
ORDRE ALPHABETIQUE DES VARIABLES
Variable - Translator
i0 000.000
i0 002.008
i0 002.009
i1 000.000
i1 002.008
i1 002.009
i2 000.000
i2 002.008
i2 002.009
i3 000.000
i3 002.008
Nombre variables : 90
ORDRE DES TRANSLATORS
Translator - Variable
000.000 i0
000.000 i1
000.000 i2
000.000 i3
000.000 kc
000.000 ks
000.000 kt
000.000 lx
000.000 ly
001.018 pp
002.000 kg
002.001 kx
002.001 ky
002.001 lx
002.001 ly
002.003 kg
002.006 kr
002.007 ks
Note that the program is not foolproof and provided to you without warranty of any kind. Bome Software has not created this program and merely makes it available as a courtesy.
1517838718387_mtpro_varlist_v6.exe
Nice,
I might try this sometime if I get a large file from someone else that is not well documented. Usually I don’t need to do this for my project files as I document all of my variables. I usually document all global variable in a preset I call “Init” with translator “Init Global Variables”. For local variables I document them within each translator. In addition to initializing them I put in comments prior to the initialization, what each is for: example
//fader 1 target
g1=0
// fader 1 current postion
ga=0
// fader 1 timer running statuts
ha=0
// precision
ia=3
I created a quick and dirty awk script that does something similar. Right now it seems to handles rules section pretty well but I have yet to figure out how to implement input and output.
I invoke it with the following *nix command
awk -f scriptfilename inputfilename | sort | uniq
Here is the script. Anyone, feel free to improve on it and re-publish/share.
Bome Q&A moderator
BEGIN {IGNORECASE }
match($0, /([x].*)(Translator.*)/,a) {tr++; name[tr]=a[2] ;}
# I don’t think I need the below unless I want to print it
#/.*//.*/ {print}
match($0,/(.*)([g-z][a-z0-9])([=<>])/, a) {var=a[2]; var2[var,tr]++ }
#;printf(“%s:%s:%sn”,name[tr],var, var2[var,tr]) }
match($0,/([=<>])([g-z][a-z0-9])(.*)/,a) {var=a[2]; var2[var,tr]++ }
match($0,/(==)([g-z][a-z0-9])(.*)/,a) {var=a[2]; var2[var,tr]++ }
match($0,/(.*)([g-z][a-z0-9])(==)/, a) {var=a[2]; var2[var,tr]++ }
match($0,/(!=)([g-z][a-z0-9])(.*)/,a) {var=a[2]; var2[var,tr]++ }
match($0,/(.*)([g-z][a-z0-9])(!=)/, a) {var=a[2]; var2[var,tr]++ }
match($0,/(.*then.*)([g-z][a-z0-9])(=)/, a) {var=a[2]; var2[var,tr]++ }
match($0,/(.*then.*)(=)([g-z][a-z0-9])/,a) {var=a[3]; var2[var,tr]++ }
# The below matches input and output but still needs work. Commenting out for now
# First
#match($0,/(^Incoming[^’]*)(‘)([g-z][a-z0-9])(‘)/,a) {var=a[3]; var2[var,tr]++ }
# Need to figure out if any others might need to iterate over the string
# Last
#match($0,/(^Incoming.*)(‘)([g-z][a-z0-9])(‘)/,a) {var=a[3]; var2[var,tr]++ }
# First
#match($0,/(^Outgoing: MIDI[^s]*)(s)([g-z][a-z0-9])(s)/,a) {var=a[3]; var2[var,tr]++ }
# Last
#match($0,/(^Outgoing: MIDI.*)(s)([g-z][a-z0-9])(s)/,a) {var=a[3]; var2[var,tr]++ }
END {
for (y in var2)
z = substr(y,3,length(y))
b = substr(y,4)
#print b,
print name[b], substr(y,1,2)
#for (x=1; x<=tr ; x++)
#print x ,” “name[x]
#print tr ” Total Translators”
I just updated my awk file that captures all global variables (hopefully I covered all cases)
It is attached below
# bmt.awk
# Document all Global Variables in a Bome BMT Project File
# By Steven J. Caldwell 11-Feb-2018
# please send any corrections to the author
# bome@sniz.biz
# Steps
# 1) Eport your project into a text file
# 2) Run the following command
# $awk -f bmt.awk filename | sort -t: -k 1 -n | uniq > outputfile
# Caputures global variables only and saves to the output file
# Format of output file will look like this
# …data excluded above
# 26.3: Bank Select LSB – gb
# 26.3: Bank Select LSB – gd
# 26.3: Bank Select LSB – gf
# 26.3: Bank Select LSB – ha
# 26.3: Bank Select LSB – hb
# 26.3: Bank Select LSB – hc
# 314 Total Translators
1518367603336_bmt.awk
this AWK script is really useful. A minor improvement is that it ignores local variables
This is a small wrapper around it that automates the grepping and post-formatting, and adds an outgoing timers (useful to show the code flow):
https://github.com/pestrela/music_scripts/blob/master/traktor/tools_traktor/bome_analyse_project.sh
This python tool shows the unused variables that are still free to use:
Hi, feel free to reach out to me via email whenever. I've made several revisions since I posted this almost a year ago. It keeps getting better.
Did you ever think about clear names for variables? Should not to hard to implement and would be really helpful if you could see
"ga - shift toggle"
"gb - option toggle"
"gc - whatever"
and so on in the dropdown. You would know which variables are already in use and what they mean instantly instead of strange stuff like documentation at some other place.
Yes that is on the “wish list”
I’ve added this post to the advanced mappings index:
When the new version of MT Pro comes out (1.9.0), we will have another 350 available global variables so the script will need to be modified again.
Umm…(droool)
Indeed very exciting.
oa-oz (excluding oo) o0-o9
pa-pz (excluding pp) p0-p9
oo,pp,qq,rr,ss,tt,uu,vv,ww and xx continue to be local variables
Was the script ever modified to support the increased number of global variables.
My project has gotten unruly and I need to go back and do the work of increasing the detail level of the documentation. The script and the python wrapper sound very useful.
Bill
I havent updated the awk script. Maybe @pedro.estrela has updated the python script though.
Actually, I guess I did update it several years ago. I don’t remember if I fully tested it.
bmt-2025-11-07-awk.txt (8.7 KB)
sorry, I’m no longer working on BOME
I recommend asking a scrip to chatGPT or Claude code
it makes wonders!
