Do you have a VERY large mapping? Do you push the limits of Bome MIDI Translator Pro? then read on.
This post is an index to useful posts/tools/info applicable to very large mappings.
Contributions are welcome. Just comment below, and I will keep the post updated.
Internals explanation:
- Be sure to check chapter 12 of the [user's manual](https://www.bome.com/products/miditranslator/support/manual): "behind the scenes"
- Exact order of operations: https://www.bome.com/support/kb/order-of-operations
- Cascaded devices: https://www.bome.com/support/kb/cascaded-presets-loopback-devices
- Devices reset: https://www.bome.com/support/kb/explicitelly-reset-a-device-or-the-whole-midimanager
- Timer Zero/subroutines: https://www.bome.com/support/kb/can-timer-zero-events-be-injected-before-any-already-buffered-messages
- Aliases and exact matching: https://forum.bome.com/t/message-at-startup/1161
- (your contribution here)
Advanced MIDI tricks:
- Overflow of downstream devices: https://www.bome.com/support/kb/error-15-midi-input-buffer-overflow
- Emulation of 14-bit HR messages using cascaded 7-bit LR messages: https://www.bome.com/support/kb/traktor-to-bome-experiences
Bome CLI tools:
- Cross reference all variables, timers, etc: https://www.bome.com/support/kb/cross-reference-list-of-all-variables-in-a-mt-pro-project
- Array emulation via compilation: https://www.bome.com/support/kb/array-emulation-using-4-sequential-variables-and-automatic-generation-of-rules
- Performance optimization / Latency graphs: https://www.bome.com/support/kb/graphs-of-usage-rates-and-latency-for-peformance-optimization
Very large mappings (to learn from them):
- Fingerlight's AKAI APC Mini: 400 presets, 60k lines export
- Dj Estrela's DDJ-1000 mapping: 100 presents, 27k lines export
- (your mapping here)
See also the bome limits in comparison to the traktor limits.
