WiFi issues on stage in a medium-sized theatre
TL;DR: How can I improve the WiFi connection between 3 BomeBoxes and our access point?
I’ll try to describe the situation as clearly as possible.
Setup
For a theatre production, I use three fully wireless MIDI keyboards, which the actors need to be able to move all over the stage. Each keyboard is connected to a BomeBox. The keyboards (Nektar Impact GXP49) are powered via the USB port of the BomeBox.
(For monitoring, a small Genelec speaker is fed with audio from a wireless IEM beltpack. The whole set is powered from a large car battery with an inverter 12V to 230V)
The BomeBoxes connect over WiFi to a dedicated access point, which is connected to a TP-Link Omada ER7212PC router.
The access point (TP-Link EAP225-Outdoor, PoE) creates a WiFi network used exclusively by the BomeBoxes. After scanning, we selected channel 11 (2.4 GHz band).
The AP is mounted centrally above the front edge of the stage. The maximum distance between the AP and a BomeBox is approximately 8 meters.
A Mac mini is connected to the Omada router via Ethernet (CAT cable). MainStage runs on the Mac and hosts the virtual instruments.
Environment
During the performance:
Large steel constructions move in and out above the stage and between the AP and the BomeBoxes
There is rain and fog
A lot of moving lights are used
Lighting is partially controlled via 2.4 GHz transmitters
So there are plenty of potential sources of RF interference.
However, this exact setup worked flawlessly for around 30 shows last year. This year, from day one, we have experienced issues with the Bome network.
Symptoms
MIDI signals arrive at Mainstage with noticeable delay
Sometimes the delay is 1–2 seconds after pressing a key
This can happen even when playing one single note on one single keyboard
So it does not appear to be a case of excessive MIDI data.
I am aware that new WiFi infrastructure may have been installed in the theatre over the past year, as the IT department improved WiFi coverage for visitors.
My question
How can I improve the connection between the access point and the BomeBoxes?
I’ve read that it’s possible to attach an external antenna to the BomeBox, and I plan to test this soon.
Possible next steps I’m considering:
Adding multiple access points (is this even posible?)
Using a WiFi-to-Ethernet adapter so I can use 5 GHz instead of 2.4 GHz Wifi
Does anyone have additional suggestions or ideas about possible causes?
Any advice is highly appreciated.
Thanks, Daniel.
