Bitwise Operations and Reference
Toggling a bit
Bit 0-31
pp=1<<xx - Where xx is bit number
ga=ga^pp
Setting a bit
pp=1<<xx - xx is bit number to set
ga=ga|pp
Clearing a bit
pp=1<<xx - xx is bit number to clear
pp=pp^-1
ga=ga&pp
Testing a bit
pp=ga>>xx – xx is bit number to test
pp=pp&1
pp will be the state of the bit - either 1 or 0
Iterating through 32 bits and output their state
Iteration timer - xx iterations -use gb=32 for interation number (note number)
start with high note and iterate down to 0
pp=gb
gb=gb-1
if gb<0 then exit rules, skip outgoing action
qq=ga>>gb
qq=qq&1
if qq==1 then rr=127
iif qq==0 then rr=0
Output 90 pp qq
On above if you want to iterate up from gb=0
pp=32-gb
gb=gb+1
if gb>31 then exit rules, skip outgoing action
…rest is same as above
XOR - If both are same, it is 0 otherwise 1
0^0= 0
0^1 = 1
1^0 = 1
1^1 = 0
AND - both bits need to be 1 for 1 output otherwise 0
0&0 = 0
1&0 = 0
0&1 = 0
1&1 = 1
OR - Either bits 1 to output 1
0|0 = 0
0|1 = 1
1|0 = 1
1|1 = 1
To make all 32 bits 1
pp=-1
Negative Numbers
Note that highest bit of a 32 bit signed integer is the “sign” bit.
When this bit is set, the value represents a negative number and the other bits are not represented by values of 1,2,4,8 etc.
To determine the negative value.
1 - Discard the sign bit (and make a mental note this is a negative number).
2 - Take the rest of the bits and invert them.
3 - Add 1 to the result
So for a value of FFFF FFFF
the sign bit is discarded and you have
7FFF FFFF
Inverting the above gives you
0000 0000
Adding 1 give you
0000 0001
So the value of FFFF FFFF is really -1.
This is really only important in debugging since MT Pro will not show the hex or binary value. It will only show the decimal value. To make it easier, download a binary calculator. Make sure it is set for 32 bit precision. Enter the value in decimal and see the result in hex or binary.
– To convert 32 bit signed int to 7 bit signed int initial value ga
// Xor with -1
ga=ga^-1
//Xor with 7f
ga=ga^0x7f
To do it with 14 bit signed int
// Xor with -1
ga=ga^-1
//Xor with 3fff
ga=ga^0x3fff
To convert for 7bit signed int to 32 bit signed int
ga=ga<<24
